It is currently Thu Jun 26, 2025 11:47 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 02, 2006 12:06 pm
It may be just the limits of my brain or of my level of comprehension of physics and trigonometry, but I am still seeing it the way Paul is. I see that the way the force is acting on the saddle and saddle slot (both the front wall and the floor of the slot) will vary a great deal depending on saddle height and saddle back-tilt, but I don't see how the total torqueing force on the bridge area could be different if the total height of the strings off the top is the same.
Let's suppose that instead of a saddle we had a low bar fixed to the bridge that the strings passed UNDER (think some sort of wide staple). Then, instead of the strings going down into bridge pin holes, they went UP and were tied to tall screw eyes screwed down into the back part of the bridge. (Again the height of the strings off the top is the same.) Have we then reversed the torque on the top? No. Have we changed it at all? I don't see how. But, like I said, maybe it's just that my brain, like the Grinch's heart, is two sizes too small.
Todd Rose
Ithaca, NY
PostPosted: Fri Jun 02, 2006 11:59 pm
I thought about this alot last night about how to explain it - I see where Paul and Todd are coming from, thinking that if the string height is 1/2 inch, no matter what the bridge saddle config is, then the torque is the same. But, do you agree that the down pressure on the saddle changes with break angle, given the string height stays the same ??? Then the torques has to change also. Why is that - because the force on the saddle is not directly down on the top - for that to be true the string would have to break down at the top at the same angle it approaches the saddle. But it doesnt do that ever. The string creates forces on the saddle as shown way back in those force vector drawings. The greater the angle the more force you get on the saddle. Rotational torque is a function of force and distance from the rotational centre, which is essentially the physical centre of the bridge. If you move the force away from the centre, the same force produces more torque - think of a wrench or socket drive - same force further away creates more torque. So, by increasing the break angle, we create more force on the saddle which is closer to the leading edge of the bridge, and thus the rotational torque will have to increase.
Paul mentioned that there are two torques, one of the saddle trying to break the slot, the other on the top - well if the saddle slot doesnt break, than that force is being applied to the top - it has to go somewhere.
There are actually two torques applied - one where the string breaks off the bridge pin hole, the other at the saddle. The two forces (not torques) may be the same total for two different saddle/bridge configs (again assuming the string height stays constant), but the position and value of each force can change, and since they occur at different distances form the rotational centre, the torque applied will be different in each case.
Todd - lets take your example of the staple type saddle with some sort of eye bolts holding the ball ends. You are correct, the torque has not reversed - why - because the direction of pull is still the same about the centre of rotation, and thus the direction of rotational torque is the same. Now want to change the torque value WITHOUT changing the tension or saddle config - thats too easy - make the eye bolts longer and the torque will go up - its a simple lever at at work - same force, longer distance - if this werent true longer wrenches wouldnt work at all.
The bottom line in my mind is if you beleive that the downforce on the saddle can be changed by changing break angle, then the torque has to change with it - you are moving the position of the force, and torque is forcexdistance.
PostPosted: Sat Jun 03, 2006 12:42 am
Great discussion folks, very educational (and a walk down Tech college memory lane for me).
PostPosted: Sat Jun 03, 2006 1:04 am
As they used to say over here during World War II "Careless torque costs vibes"
What did the bridge say to the strings? "Torque to me baby!!"
Hesh - just how many children did you have for breakfast?Dave White38871.420150463
PostPosted: Sat Jun 03, 2006 6:34 am
Maybe you are right Todd, I dont know anymore.
Back to the shop and my regular scheduled programming - off to see Tommy Emmanuel tonite here in Toronto.
PostPosted: Sat Jun 03, 2006 12:32 pm
Todd, thanks for your posts. I was hoping you might come along and clear this up for us. I was pretty sure the forces that people were describing as changing the total torque on the top would, in fact, cancel each other out and not actually affect the total torque, but I was at a loss for how to explain what I was visualizing. You did it with a simple elegance that crystallized what my brain was struggling to formulate.
Thanks to everyone who got involved in this discussion since I highjacked it from Hesh's simple question about neck angle. Whether we're "correct" or not in our thinking at any point in the discussion, I think it's good to work a bit at tackling these kind of questions - to state our current understandings of things, stumble through the sorting out of the wheat from the chaffe in our assumptions and conceptual frameworks, fill in some missing pieces from someone else' knowledge, visualize and revisualize the matter at hand, and have some light bulbs go on in our minds. This process is a big part of how we learn and deepen our understanding of things. So, thanks again to all.
Todd Rose
Ithaca, NY
PostPosted: Sat Jun 03, 2006 4:44 pm
Thanks for a great thread guys!
